So I got the points cleaned and set at the specified .017 gap. Dumped a little fuel down the carb and after a few chugs it fired up! I can only keep it running 10-30 seconds at a time as it is not drawing fuel into the line. I have the line run to the ground into a 1gal gas can and it's not picking up fuel.
Iwas trying to get it running to assess possible engine damage. Po told me that the trans and tranfer case were rebuilt then 3 months or so later the engine started to knock so they parked it. That was 5ish years ago judging by the tags and inspection stickers.
When it ran for a little bit today I first heard a slight tic tic that sounded like a lifter or something. Then the third or fourth time I had it running for a few seconds I was hearing what sounded more like a loud knock or even a bang, maybe even some metal on metal squeal. Sounded like it was coming from closer to the front of the motor then the back. Couldn't tell if it was more top end or bottom end since it would die before I could get underneath to listen.
1. Any thoughts on the no fuel draw? The fuel filter is new, so I am thinking a bad pump. If you agree, should I go with a new electric or stick with a mechanical replacement.
2. Motor noise, how should I proceed? Pull the oil pan? Pull the head? Pull the motor? Something else?
