pineneedle
My friends,
I think that I have succeeded in setting up the gears in the Dana 44 front axle that I am putting under my '67 Scout. However, working on the axle ends has led to no end of frustration. I got the axle as a housing and a box of parts. So, now that I come to assembling all the pieces after the knuckle, all is confusion. I have found a couple of exploded drawings, but there are all manner of variations of the 44, with different pieces. Perhaps someone can help me solve my puzzle. Here is what I have: a plastic sort of gasket/shim that I think goes between the knuckle and the spindle, spindle, two rubber rings/seals, dust cover for disc, and a caliper bracket. O.k., in what order do they go on? I presume that the plastic "shim" goes between the knuckle face and the spindle, but it is wedge shaped. How is it to be oriented? Furthermore, these shims are not of the same thickness; one is marked "9" and the other "11." what gives?
As for the dust cover and bracket, which goes on first, and how are they oriented? By oriented, I mean, does the bracket go on the back side of the wheel, and if so, at about 10:00?
If anybody has a nice exploded view of the Dana 44 used in the Scout II, I would be forever in your debt if you would scan it and send me a copy. Thanks in advance.
Pineneedle john
Pineneedle john
