Window Regulator Issue-
dmf6978
So today was a nice day so that means work on your truck day. Fixed up some rust spots and decided to re tackle my driver side window. I had removed the entire assembly last year so i can put in new weather stripping. I noticed my old window crank was broken so i had bought a used one. Managed to get it in, but then last month over cranked and it somehow came off the spindle or whatever you want to call it. Took the entire thing apart and realized the arm on the crank is at some weird angle. Is this normal, or did some asshole play a trick on me and sold me bad used part? Truck is for a 67 1200B 304 Pickup. I know you guys are pros at this so maybe you can help me before i go and buy yet another used part to try. I think this is why I was having such a hard time getting the crank arm into the window slot holder on the glass.
dmf6978
The old one is in blue and the original i think was the straight arm one, but I cant seem to get the teeth to drip the handle roller.
