Why do some carbs flood and others don't?
Hi,
another post ended with the words, "you also won't have flooding out issues when off roading." which got me to thinking...
I'm far from a carb expert and its probably my weakest link, but I have always wondered, why does an off-road truck carb flood out but the carb on an off-road bike doesn't? I've seen some off-road bikes take some extreme angles, and with some intense vibration, but a truck doing half that angle will choke and flood out. Why can't the same principles be applied or modifications be done to an off-road truck carb as to an off-road bike's carb?
Thanks.
Steve
Another post ended with the words "you also won't have flooding out issues when off-roading."
the post was talking about fuel injection....
Motorcycle carbs are typically slide-valve carbs, completely different than automobile carbs.
You could custom install a motorcycle carb or two on your truck if you had the mind to.
I have seen one and it works.
Some carbs do and others don't. The 2210 that came on my Scout has never missed a beat when wheeling even at crazy scary angles. I believe that the flooding issue is primarily a design issue.
If you think about it a motorcycle carb has a float that almost fills the bowl, hence it is always in the fuel. A carb with a big fuel bowl and a small float that's not located in the center bowl would be much more likely to flood at an angle.
Another factor is float buoyancy vs. Weight. If you've got a heavy float that sits low in the fuel and hit a bump it will be a fairly long time before the float rises back up in the fuel and shuts off the supply. Now you're flooded.
