Where can I find 345 water pipes??
T8rchips
Not only am I new to the IH world, but I'm fairly new to in-depth engine work as well. I purchased a 1973 International step-van with a 345 that's been sitting in an orchard for 16 years. (I paid $50 for it) I'm planning to turn it into a micro home, but alas, the engine needs to run for that to happen.
The cooling system is pretty much as rotted as rotted can get. The freeze plugs, radiator, thermostat, hoses, and water pump are easy enough to find, but what about the water pipes running in to and out of the engine on either side of the water pump?!?! The IH Parts of America store has been sold out of them for quite awhile and that seems to be the case with every other place online that I've looked as well. Does anyone have a resource that they can share where I might be able to find both the inlet and outlet water pipes?? I'm at a pretty big loss and I thought that forums would be the next best step.
Hopefully this question is appropriate here. Thank you!!
Im sure some of the IH dealers have some laying on the shelf used. Navistar quit having new ones made I believe.
Only other thing that could work is getting the pump housing and heads tapped for NPT fittings.
FDChappie
Active member
In my experience, when the cooling system is that bad, the steel shim head gaskets are too. It might be a good idea to pull the heads while things are open.
Scooter
Active member
Might give the guys up at IH parts America a call. About 6 years, I was able to get both water tubes for an IH 266 while helping a friend work on his 69 scout 800. IHPA should have the O-rings for them tubes also
