Just had the fly wheel resurfaced,replaced throwout bearing,clutch fork bolt/bushing,slave,master ect,did not replace clutch as funds were short and it appeared fairly new,you could still see the cross hatches on the pressure plate and the disk is almost thick as new.also added to the clutch fork with a weld on each side and reshaped the metal so it fit the to bearing collar so the is no slop in it.as I reassembled everything it became obvious the to bearing wasnt going to move the three fingers very fall if at all,as you can see in the pic the clutch fork is almost up against the bell housing with no pressure on it.is the clutch just completely shot and the fingers so worn the to bearing isnt going to move it?could the fork be bent or misshapen?did I assemble something incorrectly?any help appreciated.
