If the vehicle under discussion is a Scout II, then the original setup if a four speed would be a warner gear t19 witha married Dana 20 transfer case. If it's a Scout II from the first production year, we refer to those as the "810" model and it could be a t18 with d20.
Married transfer case means it's bolted directly to the adapter housing on the back of the transmission.
A divorced transfer case means it's separate from the transmission and connected by a really short drive shaft. No Scout II had a divorced transfer case from the factory.
If the transfer case is aluminum, and the control for it is a push/pull knob on the dash, then it's a chain drive single speed case, mounted behind a three speed transmission (warner t90 moist likely).
Both the transfer case and the transmission originally had metallic "tags" under a bolt head somewhere with an IH code number and part number, if you can find those tags, post the numbers and we can decode 'em for ya.
