what heads are these?
I don't believe so. They're non-improved cooling heads, the water ports won't match the block.you need late model 345 heads. Jeff
I sure don't. Everybody is using the imp cooling blocks now. The non-imp cooling blocks are the only 1's you can use older 345 heads on to boost compression.
