overdrivesteve
Hi,
I'm trying to get an understanding of the oil lubrication recommendations for our trucks. This is a quote from your swepco pdf:
"it is manufactured from the very finest high vi paraffinic base stocks"
but what is a base vi stock and where does it fall in this quoted description of base stocks from this http://www.widman.biz/uploads/corvair_oil.pdf Source:
• group I - oils are solvent refined and normally low in natural viscosity index, although
some oil fields produce better grades than others. They have 20 to 30% aromatics, high
nitrogen and sulfur.
• group II - oils are hydroprocessed oils (or solvent refined and then hydrotreated).
Normally 92% to 99% of the molecules are saturated in the bombardment of hydrogen,
creating a clean, stable base oil and eliminating almost all aromatics, sulfur, and nitrogen.
• group II+ - oils are hydroprocessed to a quality somewhere between group II and group
iii.
• group iii - oils are severely hydroprocessed, creating base oils that under some conditions
give equal performance to traditional synthetic oils.
• group iv - oils are pao (polyalphaolefin) synthetics. These are excellent lubricants but
have very low solvency when used by themselves, not mixing well with other oils,
additives or contaminants, and causing hardening of seals and gaskets. Fully formulated
pao based oils use esters or other ingredients to increase their solvency.
• group v - oils are everything else synthetic. In general the esters and diesters of various
formulations are used to mix in small percentages with pao oils to give then the
necessary solvency and help them maintain a clean engine, softening the seals to avoid
leakage. The category also includes other types of oils used for specialty products or to
thicken group I, II, iii or iv oils.
and also can you please comment on this quote:
" shear strength of the base oil is more important than a few parts per million of zddp.
Synthetics will give the best protection, with group II oils next."
thanks.
Steve
iii.
thanks.
Steve
