Weber 32/36 linkage
choxie
I know the weber 32/36 conversion is a popular mod. I have searched for info specifically on fabricating linkages but cant find what I need. Has anyone been successful setting up a cable linkage for the weber with "push up" linkage?
Thanks
cameron
I don't recommend a push to open system with a cable for a throttle. The cable you should use like a lokar type is pull only. The heavy push-pull morse marine type is not suitable.
If you must push, you'll need to fab up a linkage and bell crank situation. Don't know why someone would chose that route however.
