Wanted Loadstar air filter housing
Hi,
I'm looking for a loadstar air filter housing assembly. I prefer the one that uses a wix 42697 paper filter that's about 12.6 inches in diameter by 5 inches high.
Or as a second choice, the filter housing that uses the wix filter 46255 that is about 11.6 inches by 5 inches high.
Or as a last resort, I will also consider the loadstar oil bath filter assembly.
Please email or post pictures of what you have and let me know your asking price. I'm looking for something dent free.
I might be interested in other large IH air cleaner filter housings too, so let me know what you have.
Thanks.
Steve
here is the list of air filter housing applications for the larger 12.6 in. Diameter filters -
ihc/navistar+trucks & buses s1600 v8 5.7l 345 cid gas
1600 loadstar series w / International v345 (5.6l) engine
1700 loadstar series w / International mv404 (6.6l) engine
1700 loadstar series w / International v345 (5.6l) engine
1800 loadstar series w / International mv404 (6.6l) engine
1800 loadstar series w / International mv446 (7.3l) engine
1800 loadstar series w / International v345 (5.6l) engine
1800 loadstar series w / International v392 (6.4l) engine
the slightly smaller 11.6 in diameter filters could be found in anything from pick-up trucks to 2 ton trucks.
---new edit---
I'm not sure why this 9 month old part-wanted posting was brought up, but its interesting to reflect on how much I've learned in the past year, starting from zero IH knowledge in December of last year . but I can still count on less than one hand the number of IH vehicles I've ever seen in real life .
I'm not looking for the air cleaner housing any longer, so its ok by me if this entire thread was deleted .
steve
Hi,
to make it easier to understand what I'm actually looking for, I attached pics of the two styles of air cleaner housing desired.
Note, what they have in common is they both work with the loadstar 2 barrel carb, they both use large paper filters that are between 11.5 and 12.6 inches in diameter and 3 to 5 inches tall, and they do not have a pcv hose connection on the top of the housing.
Let me know if you find any such things in your local wrecking yards.
Thanks.
Steve
