wanted: dana 44 rear for 1100d
ybda65
Need 4:09 powerloc 5 lug bolt for my 1/2 ton, or even better a Dana 60 this for '67 I wanted a complete differ. Prefer it be in no. Cal or south. Ore.
Ill check the gearing in the few that I have. Im in cottage grove oregon. Im sure I have it just have to look through the parts trucks
541-968-8425
scott
I got 1 in a '70 1000 d t'all in ohio..Jeff (d-60)
Jeff I just realized you sent me a e- from early aug, thanks I had aproplem w/ this e- address, someone tryed to get into it, so gmail shut it down, till I could confirm, my acct. Anyways, what gears and is it a 5 bolt w/ posi? Lastly are you coming out west in the near future, I don't know how much that would weight for freight? How much if it meets all those standards? Thanks david
ill check the gearing in the few that I have. Im in cottage grove oregon. Im sure I have it just have to look through the parts trucks
541-968-8425
scott
Scott I'm still looking for the diff. I posted, have you ck'd your rigs for my 4:10 rear, w/posi?
Darren I wanted to p.m. You could'nt so would you e-mail me at ihrestoration@gmail.com Are the gears etc. Quite? I'll reply p.m. If I can figure how to but hoping you'll respond via e-mail outside david
Ok, didn't get your msg, but the one out of the '68 is the original which is actually a c-series, but I also have another parts truck '72 1210 d series but that's an 8 lug Dana 60
I have a heavy duty Dana 30 front with new ball joints. Also has discs and calipers two sets of drag links two set of knuckles. With 3.73's with an open diff. I am in northern California.
They were in my Scout ll. I just replaced every thing front and back on my Scout ll with upgrades so I dont need these at all. I would like to sell both if poss. For a reasonable deal. If they work for u.
Sorry, I believe the diff's on scouts are narrower then the full size p.u.'s my fromt diff. Is a 44 w/ 4:09 gears. I want to stay w/ 44 in front! And want 4:10 for rear. Yet if pull came to shove I'd change out fronts, but 5 lug, with disc's 44's thanks though
