Evening, folks.
I recently bought a '73 wagonmaster 1010 that a po had put in an olds deisel 350 long ago. Since it had been altered already (and that engine has been out of it for 15 yrs), I opted to put in another olds that would bolt up, and it sounds awesome. It's at a transmission shop today to have the center support bracket and u-joints replaced, so it is very close to coming back to life after sitting outside up in or fir 15+years and I am very excited about this old piece of IH steel.
Michael mayben provided me with the wiring diagram needed for me to rewire the ignition, starter, ignition switch and hei - and it cranked, ran and turned off on the first pass (thanks, michael for that and your other input!).
However, on an earlier pass of wiring it, when I left the battery hooked up over a couple of days, the battery was dead. So, in an effort to see if the rewiring job also corrected that problem, I turned the key to the 'off' position (at least I believe I did), and then let it sit for a couple days. Again, battery was drained. I know when I opened the door, the courtesy light came on briefly, then turned off. I thought that was odd, and turned the key and no sound whatsoever, and no lights.
Now, I cannot jump start it and charging the battery doesn't resolve it either.
It is a new battery, new ignition switch, newer starter, and the darn thing ran 5 days ago.
Could I have damaged the hei or something else if I did accidentally leave the iginition set to 'run'?
What should I look for tomorrow morning when I go down to check it out?
Thanks in advance, all, for any response!
