I've been searching for the source of the noise in my 345. I have read up on all the oiling posts and I'm still going to investigate that further if necessary. It's always had a slight tick, but recently it has gotten worse and takes longer to go away after start up.
I was cleaning out my heater core today and happened to see a gouge in the vacuum hose from the intake (#8 runner) to the brake booster. I could feel a small leak, but when I messed around with the hose, the leak opened up. As soon as I did that, my "lifter noise" started but it was much worse. I had only heard it that bad once before. It sounded like the whole bottom end of the motor was going to come loose.
Fixed the hose, now we'll see how that noise is after a few days.
Nathan
Nathan
