travelall 4x4? on craigslist
It is an 1110, 304, 4-speed divorced 205. Dana 44 front and rear. Front is a closed knuckle drum brake.it is in decent shape. The worst rust is around the windshield, then some miner dents here and there.
it is an 1110, 304, 4-speed divorced 205. Dana 44 front and rear. Front is a closed knuckle drum brake.it is in decent shape. The worst rust is around the windshield, then some miner dents here and there.
The grill and closed knuckle steering axle tell me it's not a '73 unless the parts have been swapped around. What's the data plate say?
If the grille has a removable "insert", then it's most likely a '71, if the grille is one piece, then it's '70.
'69>'71 share a parts list, mt-124, '72>'73 share the mt-131, and '74/'75 share the mt-136. Just want ya to know that these rigs are "not all the same" and have many detail differences spread over the production duration.
From the data sticker on the door jamb
vin format: 1972 International light truck
decoding: b17007h2*****
digit usage vin decoded
1 line b 1972 pickup/Travelall
2 drive 1 2wd
3 series 7 Travelall
4 size 0 Travelall 1/2-ton
5 engine 0 v8 gas (pickup or Travelall)
6 body 7 wagon (Travelall)
7 plant h springfield, ohio (pickup & Travelall)
8-13 sequential serial #
from the plate rivited on the door
vin format: 1966-1971 International light truck
decoding: 143107h******
- mfg year/month - 1971
1-4 model 1431 unknown!
2 drive 4 awd
4 size 1 1000/1100 1/2-ton
5 engine 0 gas
6 body 7 wagon (Scout or Travelall)
