Transmission Slipping?
Jason
Hi again,
my 73 Scout with 345 and 727 auto 3 speed transmission is slipping. Here is what is going on. I have been getting a slight slip when when it shifts from 2 to 3. It would not slip if I was really on the gas. So this weekend I drained the tranny and changed out filter and atf. After put everything back together. I took it out for a test and now its slipping really bad form 2 to 3. It shifts great from 1 to 2. Dose this mean I need to pull the tranny and rebuild? Or are there a few things I can check or do to try and fix? Thanks again for any help.
Jason
Wait a minute...you drained the trans and did not service both bands??
Had you serviced the bands and the transmission issue was resolved, then ya move on. If you serviced the bands and the tranny situation did not improve, then ya schedule it for a rebuild!
Ya michael, I just drained the trans with no service:icon_stressed:. I have been ready the thread on how to adjust the bands. I will go back and drain the tranny again and try and see if I can work on adjusting the bands and hope and pray that will fix my trans problem. Thanks for getting back to me on this.
Jason
