Ok I put in a wide ratio t19 in my 73 Scout II. I had a close ratio in it before. Now my clutch linkage is not lining up right. I used the mount off the old trans and had a semi hard time lining up the cross member. Now it seems to sit to tall. The bottom of the new t19 seems lower raising the whole trans up thus throwing off the balls for the z-bar. Is there a shorter or different mount I should use? It has raised the ball on the trans about 1 inch I bet. I'm just guessing on that maybe less.
Ben
Ben
