Mark Ashford
Were and how does/should a 727 (Scout) tranny vent?
Off-road application, so any vent would need to be closed or remote mounted to keep the crap and water out.
Iirc the main vent is in the front of the housing behind the converter. And iirc also for off-road application its wise to plug this vent avoid sucking in water or other junk as well as in a roll-over situation.
1) whats the recommended method of plugging this? Without tearing the tranny apart to clean out any shavings from a drill and tap procedure.
2) is there an auxiliary vent one can tap into for a remote breather?
3) how much "breathing" does a 727 need? Common practice for differentials and t-cases lately has been to use basically a little rubber "bellows" that allow expansion and contraction of a fair amount yet it still keeps everything sealed and keeps fluid from escaping when you go greasy side up. Would this be sufficient for a 727?
