throughout bearing
snoman
Hi just picked up a 1972 IH 3/4 ton pickup for a plow truck it is a 4 speed with a 345. Think the throughout bearing is going makes a lot of noise when the clutch is let out. Anyone have a step by step how to for me?
Thanks
Try a shot or 3 of grease. It's worked for me. Remove the inspection cover on the bottom of the bell housing and see if there is a zerk fitting on the collar the bearing is on. Don't use to much grease as it can get on your clutch disk and you'll have bigger problems.
