Ok, this is about my little brother's Scout. '76 Scout II, 345, 727, "gold-box", 2v carb, all apparently stock. He bought it at an insurance auction, so we can only can only speculate on it's history.
The truck actually starts, idles, & runs great. Hot oil pressure on the freeway is 40 psi, hot idle 10 psi. It has loud tick on the passenger side. Once it's warm, the tick goes away at idle, but always loud at freeway speeds. Investigation showed a fair amount of wear on the rocker shaft, replacement is in order. Observation shows lots of oil flow to each of the rocker "boats" at idle. 7 of the lifters spin merrily in their bores, 1 just goes up & down. We replaced that 1 lifter, the bottom was cupped pretty badly. The new one still doesn't turn. I think we've established that we've got a bad cam lobe.
This Scout will be a trail rig. It will need to drive several hours to the trail head, but won't see the miles of a regular driver.
Ok, here's the questions:
1. We'd love to re-build the engine, but time & budget won't allow it yet. I have 2 stock cams and 4 "welded" rocker assemblies. I haven't measured the cam lobes yet, but they appear sound. I want to swap out the bad cam and worn rocker assembly, and just run it that way for a while. Is it reasonable to think the cam bearings have some life left in them? Do you guys think it is worth the trouble to swap out the bad parts?
2. Would we be better off not touching it and just running it until we can go through the whole thing and fix it right?
3. Should we leave the cam alone, and swap in one of my better rocker assemblies? I was hesitant at first because I didn't want to damage good parts, but since then I've been thinking that we verified oil flow and the pressure reading is good, so why not? I should have measured lift on the bad lobe, but I didn't think of it at the time. Still, the valve is actuating, probably not all they way, but it's not a dead cylinder.
4. I'm betting the rocker shaft was damaged by skipping oil-changes, since oil flow appears fine, and I've verified oil volume. Should I be worried?
I'd love to hear your thoughts.
