The continuing adventures of Mo-binder
Things are pretty slow at work, so I'll bore you with this:
15 years in the process:
The specs
engine:
383 mopar 1966
cr 10:1
forged steel crank turned .010
sterling pistons +.030
block/heads decked .020
sealed power rings
clevite 77 crank and cam bearings
mopar performance camshaft 268/284 duration .450/.465 lift
mopar performance hydraulic lifters
stainless valves 1.81 / 2.42 inch
mopar performance valve springs and rockers
mopar performance double row timing set
melling high capacity oil pump
mopar performance windage tray and oil pan
weiand intake manifold
mopar performance water pump
mopar performance distributor/ignition, jacobs coil
edlebrock 1406 square bore carb.
Mopar performance mechanical fuel pump
transmission:
custom built by Mike mayben
new clutches & bands
bolt in sprag
tc anti drain back
case mounted breather
ceramic output shaft bearing
axles:
4:10 gears - chrome diff covers
rear: detroit locker
front: lock right locker
stock axle shafts 30 spline
all new bearings/seals
transfercase:
stock. New bearings/seal
brakes:
4 wheel discs
GM hydro boost
corvette master cylinder
dot 5 fluid (synthetic)
stainless brake lines
Chevy rotors - rear
cadillac calipers - rear
engine compartment misc:
dual batteries
marine battery switch
flex-o-lite black magic electric fan
remote transmission filter
remote power steering filter
remote 24 oz fuel filter
dual transmission coolers, valve selectable
new 3 row radiator
hella air horn
on board air w/2 gal tank and coalescing filter
automatic reset circuit breakers & 30 amp relays
firewall mounted breather for axles and tc and trans
borgson steering joint
interior:
mastercraft seats and 5 point belts
custom anodized aluminum dash
vdo gauges
autometer a/f mixture gauge
hobbs hour meter
vacuum gauge
oil temp & trans temp gauges
air pressure gauge
fuel pressure gauge
circuit breakers
B&M mega shifter
grant st wheel
granite roll bar c
custom window cranks
full carpet kit
cobra ssb cb
yaesu ft 7800 2meter/440 radio
exterior:
ppg acrylic enamel paint
por 15 on complete tub
sss fiberglass rear quarters
fender flares
granite custom bumper
warn 8274 winch
kc daylighters
light source driving lights
custom tube rear bumper
4 high intensity backup lights
two piece tail gate conversion
'09 dodge challenger fuel fill door
chassis/suspension
rancho 9000 shocks
rancho 2” lift springs
2” body lift
custom spring plates
poly spring bushings
por 15 on complete frame
2” body lift & poly body bushings
fuel tank skid plate
class 3 tow hitch
Not at all boring terry!:icon_up:
good look'in, and all the right equipment in all the right places.
Like a woman some can only dream about:ihih:
thanks for sharing.
