76bluescout
Hey all, my names chris, ive been lurking here for a cpl weeks now after I just picked up my first Scout. A 1976 4x4 Scout with a 345 and a automatic transmission.
To make a long story short I picked up the truck from a guy and he mentioned there was a "hole" in the origionel transmission that he had welded up right before I bought it. It drove fine for 1 1/2 hours of clearing snow with the plow right before I bought it so I didnt think much of it till I got it home and after 2 passes on the driveway reverse and drive were pretty much gone.
( ohhhh hun you know that truck that you didnt want me to buy....I might need to go buy a transmission) mmmhmmm that went over well
anyways the welding shop had decided to try to weld the casing, melted it in from what I can tell, and when they figured out that wouldnt work, they went and bought 2 lbs of jb weld and plastered it over the casing. Sooo I was off to the boneyard to find one and happened across another one that I was told was out of the same year Scout. I had done some reading up on mm's stickys ( good info btw ) and made sure they had the same bellhousing ect and that I wasnt getting something that wasnt from an IH.
Everything matched up so now im trying to put it up to the motor and the bellhousing is correct but the converter bolt holes that came with the new trans are closer to the center by what looks like from what I can tell about 1/2 - 3/4 of an inch compared to the holes on the flywheel. Did I screw up and grab an oddball trans? Or did they have different flywheels and converters on the smaller motors? Im at a loss here, any help would be appreciated. Thanks!
