Matt G
Here's the deal: 74 Scout 2 with all stock wiring. The rear lighting harness was butchered fairly bad at one point by a po for a trailer light hookup.
'bout a week ago I lost the left brake light, but the left blinker (which uses the same bulb filament and same wire to the tail light housing) works fine.
Mayben helped me work through some grounding issues I had back there which have now been rectified by running new ground wires from both light buckets to the body. Everything now grounds great and the left brake light worked again for a couple days. But I just lost it once again - blinker still works fine, as does the right brake light (actually, all other lights on the rig work perfectly).
So, novice electrical chump that I am, I deduce that the problem must be on the power side of this circuit, not the ground side. If I understand my wiring diagram correctly (big if) the brake light circuit runs from the switch on the brake pedal to the big "fan" connector on the steering column. There it merges (through the turn signal switch?) with the circuit for the blinker, and both signals then use the same wire out the bhc and back to the tail light. Is that right?
If so, the problem would seem to be with the turn signal switch itself? Since the blinker circuit works perfectly I deduce that there's no connection problem between the steering column and the light bucket. And since the right brake light works perfectly I deduce that there's no problem between the brake light switch and the fan connector. So it must be the connector itself? That connector and the ignition switch above it are uncharted territory for this novice.
Any advice?
Any advice?
