table testing
<table border=1 width="100%">
<tr></tr>
<tr bgcolor=peachpuff>
<td align=left width="20%"><b>IH model<br>IH code</b></td>
<td align=center>ra-5 / ra-6<br>14005 / 14006</td>
<td align=center>ra-10 / ra-11<br>14010 / 14011</td>
<td align=center>ra-15<br>14015</td>
<td align=center>ra-20<br>14020</td>
<td align=center>ra-25 / ra-26<br>14025 / 14026</td>
<td align=center>ra-30 / ra-31<br>14030 / 14031</td>
<td align=center>ra-32 / ra-33<br>14032 / 14033</td>
<td align=center>ra-35<br>14035</td>
<td align=center>ra-40<br>14040</td>
</tr>
<tr>
<td>axle type</td>
<td align=center>semi-floating</td>
<td align=center>full floating</td>
</tr>
<tr>
<td valign=middle>ratios</td>
<td align=center>3.73 : 1<br>4.10 : 1<br>4.77 : 1</td>
<td align=center>4.10 : 1<br>4.77 : 1<br>5.13 : 1</td>
<td align=center>4.300 : 1<br>4.875 : 1<br>5.571 :1<br>6.166 : 1</td>
<td align=center>4.875 : 1<br>5.571 : 1<br>6.166 : 1</td>
<td align=center>5.285 : 1<br>6.166 : 1<br>6.666 : 1<br>7.166 : 1</td>
<td align=center>6.166 : 1<br>6.666 : 1<br>7.166 : 1</td>
<td align=center>5.571 : 1<br>6.500 : 1<br>7.166 : 1</td>
</tr>
<tr>
<td>serial number location</td>
<td align=center>on bolt circle of differential</td>
<td colspan=10><b>pinion</b></td>
</tr>
<tr>
<td>drive</td>
<td align=center>hypoid</td>
</tr>
<tr>
<td>mounting</td>
<td align=center>straddle</td>
</tr>
<tr>
<td>nominal dimension (? Inches ?)</td>
<td align=center>2.6094</td>
<td align=center>2.9830</td>
<td align=center>3.2530</td>
<td align=center>3.4725</td>
</tr>
<tr>
<td>se-1065-0 disc</td>
<td align=center>a(2)</td>
<td align=center>n(2)</td>
<td align=center>d(2)</td>
</tr>
<tr>
<td>cage rotating torque scale reading (pounds)</td>
<td align=center>3 to 8</td>
</tr>
<td colspan=10><b>differential</b></td>
</tr>
<tr>
<td>case type</td>
<td align=center>one piece</td>
<td align=center>two piece</td>
</tr>
<tr>
<td>number of gears</td>
<td align=center>2</td>
<td align=center>4</td>
</tr>
<tr>
<td>bearing preload</td>
<td align=center>1 notch each side</td>
</tr>
<td colspan=10><b>housing</b></td>
</tr>
<tr>
<td>type</td>
<td align=center>banjo</td>
</tr>
<tr>
<td>lube capacity (pints)</td>
<td align=center>5-1/4</td>
<td align=center>5-1/2</td>
<td align=center>9-1/2</td>
<td align=center>8</td>
<td align=center>11</td>
<td align=center>12</td>
</tr>
<td colspan=10><b>axle shaft</b></td>
</tr>
<tr>
<td>number of splines</td>
<td align=center>10</td>
<td align=center>16</td>
</tr>
<tr>
<td>diameter at splines (? Inches ?)</td>
<td align=center>1-9/32</td>
<td align=center>1-33/64</td>
<td align=center>1-3/4</td>
<td align=center>1-7/8</td>
</tr>
<tr>
</table>
well, I guess I can't post tables here.
I see html is turned off below - is that something I can turn on or set for my posts, or is that a moderator-only control?
Steve
  • Delco-IHC-tach-drive-parts.pdf
