I recently bought a T90 rebuild kit from IHPA which honestly was a disaster because 70/80% of the parts were not right for my transmission which I took out of a 70, 800. This is not a bitch session about that but I feel people need to know that it is not the right kit.
My question is how do you get the right parts or are they unobtainable? Also, I need to get some gears such as reverse and the multi-gear, gear cluster as well.
Parts from the kit I could not use:
Blocking rings incorrect.
Thrust washers too small.
Synchronizer shift dogs incorrect.
Input shaft seal too small.
Input shaft needle bearings too large.
Synchro shift springs incorrect.
Things we were able to use.
Front bearing
Rear bearing
Cluster gear needle bearings and 6 washers.
Front bearing
Rear bearing
