T496 5 speed
David K.
I have a T496 transmission in my 1974 travelall it is a 392 4x4. I am posting because this spring I am going to be replacing the clutch, pilot bearing, and throw out bearing as they are making noise and the clutch is the either the original or its old and worn. So I was wondering if anyone knew the correct clutch, pilot bearing, and throw out bearingfor this setup. I know from factory that it had a 11 inch disc and 6 springs but on the line settting ticket it is written in as a 12 inch disc with 12 springs. Then my next problem is what oil to use in this transmission.
