T19 transmission
Hondo
800 sounds a little high, but the groove I see around the splines on the input shaft indicate it is probably a wide T19, which makes it a little more desirable. You can verify by getting it in first gear then rotating the input shaft while watching the output shaft. Close will be 4:1 wide will be 6.32:1.
IHZW
Thank you for your help. I really appreciate it!
