Iirc, the shifter assy. Is the same for both units, so the manufacturer did not recast the top cover with (t-18) on it when the trans model was changed. So most t-18 trans will have a top cover identified with "t-98" on it. This has been known to cause confusion in identifying these models of manual transmissions.
The case should be properly identified with "t-18" or similar casting.
