mitchdawg22
Hello,
I have a 1967 Scout 800, with a 345, Scout ii axels, rebuilt T-19 transmission mated to a Dana 20, all of which were installed or rebuilt in a partial restoration about 2,000 miles ago. I'm having some issues with the transmission, I haven't seen any similar issues in other posts, apologies if I missed it, but wanted to see if others may be familiar with the symptoms before I pulled it...appreciate any help in advance!
There are four issues:
1) When cold, it sticks a little in first when trying to shift into second. No problem once it's warmed up.
2) When upshifting into second, 9/10 times, it's difficult to shift; you have to apply a decent amount of force and there's feedback (not grinding) but resistance against getting it into gear. Double clutching doesn't solve this problem. 1/10 times it shifts flawless.
3) When down or upshifting into 3rd, it either grinds and won't go into gear at all or you can feel some resistance / feedback. Almost like a hitch when you try and put it into gear. Rev matching helps on the downshifts but it's not perfect.
4) When idling or in gear driving, there is a rattle and vibration coming through the clutch pedal. If I very lightly depress the clutch pedal, it goes away. I've maxed out the clutch adj, I can't seem to solve it unless I cut the clutch linkage down.
My first thought was that the synchros are worn, however, the transmission was just rebuilt and it sounds rather rare to have two worn synchros in a T-19 with such low mileage. Also, I would think double clutching should eliminate the synchos but that doesn't seem to make the shifting more smooth, especially into and out of 2nd.
Could it be a throwout bearing issue? Or the clutch fork? Lubrication or fluid? All of the above?
The Scout had been stored and not run for about 9 months. These issues started about 200 miles after it was run again.
Many thanks in advance.
