For the most part the comments from Scout-it-out are correct. The commonly seen oils on the market were made for "competition" purposes. No, I don't mean "high performance competition," moreso the competition in price with each other. Mobil, royal purple, redline and amsoil have seperated themselves from the rest of the bunch and probably have some of the better results than others do due to their chemistry, however out of all of them, redline is probably the only true synthetic oil and the others are either blends, or made basically from petro stocks.
Before the market was blitzed by castrol back several years ago advertising synthetic oils, it was common that the oils then could actually cause seals to dry up and shrink, causing oil leaks. This was because synthetics have a naturally high detergency factor. If I recall correctly, amsoil had a full synthetic at the time and suffered the same results...they eventually re-formulated and came out with a "semi-synthetic" oil. Most of the semi-synthetic oils (pao's) on the market do not hold additives in suspension well and therefore depend a lot upon the strength of the base stock to provide the better part of taking care of the lack of zddp. However with the newer class which use a petro-stock to start with and different refining, that has now changed. They are legally (according to the ftc) able to be called "full synthetic" because they have synthetic-like properties. They accept additives more readily than the semi-synthetic (polyalphaolephins - paos) do.
Since 2007 when the api introduced the classification of "sm" and now "sn" for gasoline service, the zddp in these automotive specifications was lowered to around 850ppm which is well below what was normally available in the previous "sl" rated oils. In my estimation, this is the first time an api recommendation went backwards in quality, and it was just to save the possibility of poisoning catalytic converters.
Swepco's 306 engine oils in the 10w30, 15w40 and 20w50 are rated "sl" and have a high concentration of zddp which can be used in all gasoline engines prior to 2007. It also meets ci-4diesel specifications and has a much higher zddp content than the rotella-t oil mentioned. The cj-4 diesel specification limits the zddp to around 1,100 ppm whereas swepco 306 comes in at around 1,600 ppm.
The above examples reflect the addage that "you get what you pay for," or another way of putting it: "you get your monies worth."
additional information on swepco engine oil will be that they do not just make an oil for "older (pre-2007) vehicles," they also manufacture the sm-sn specification for gasoline engines with their "303" engine oil, which is a semi-synthetic, and for diesel engines calling for cj-4, it would be the "308" engine oil with a 5w40 semi-synthetic or a 15w40 straight petro stock. All of these oils conform to the applicable specifications to qualify for those designations.
A lot of this information has already been covered in past oil tech threads, those threads should be reviewed before posting, however since it has been awhile, I elected to respond after the reply was made.
Hope this helps clarify things for everyone.
Dick
