DF Sales&Marketing
Oil Tech Moderator
Energy star® is a joint program of the u.s. Environmental protection agency and the u.s. Department of energy helping us all save money and protect the environment through energy efficient products and practices.
Results are already adding up. Americans, with the help of energy star, saved enough energy in 2008 alone to avoid greenhouse gas emissions equivalent to those from 29 million cars—all while saving $19 billion on utility bills.
Because a strategic approach to energy management can produce twice the savings—for the bottom line and the environment—as typical approaches, epa’s energy star partnership offers a proven energy management strategy that helps in measuring current energy performance, setting goals, tracking savings, and rewarding improvements.
Southwestern petroleum, manufacturer of “swepco” brand lubricants is proud to announce that they are the first and only manufacturer of industrial and commercial lubricants to be recognized as an energy star® partner by the u.s. Department of energy (doe) and the u.s. Environmental protection agency (epa). This achievement is the result of a detailed review of swepco case studies and energy savings program audits, documenting the ability of swepco energy conserving lubricants to help our customers improve energy efficiency in real world operations.
This documentation was essential to our acceptance as an energy star® partner … which ultimately means you can be confident when you choose swepco that you have chosen a partner who has the experience, products, technology and commitment to help you…
achieve your energy efficiency & conservation goals.
Earn energy star® recognition for your own company.
Reduce your electrical loads as much as 5 to 12% or more.
Cut your diesel fuel costs as much as 4 to 10% or more & cut emissions.
Reduce your oil consumption on average 50-66%.
Reduce waste oil disposal.
Reduce friction, wear and operating temperatures on your equipment.
The same is true for fuel powered tasks. Part of the fuel is consumed in overcoming internal friction; the balance is actually applied to the work being done.
As swepco lubricants reduce the friction that increases energy consumption, they also reduce the wear that shortens equipment life. So you get the added benefit of lower maintenance and repair costs and longer equipment life. And because swepco brand lubricants deliver drain and re-greasing intervals that are typically three to five times longer than conventional lubricants, they save the environment too.
Ihon stocks most automotive - type products, grease, gear oil, engine oil, transmission fluid & power steering oil. Please contact Jeff for your personal needs. For industrial applications and other products, please contact me with a pm for more information.
"swepco.....solutions to keep it running"
dick
how does friction cost us all money?
It is simply really. Electrical energy applied to a task is split between the work that is done and the energy lost to friction in the form of heat. The goal of a lubricant is to reduce the ratio of friction to work. The same is true for fuel powered tasks. Part of the fuel is consumed in overcoming internal friction; the balance is actually applied to the work being done.
what can you do about it?
The truth is that not all oils are the same; nor are all greases. There are important differences in oil base stocks, additive chemistry and formulation technology. And your choice of lubricant has a direct impact on your energy use. The ability of swepco lubricants to reduce friction and energy consumption has been proven in a wide range of demanding applications around the globe. Our energy star® partner status helps establish our credibility in this important area. From reducing amperage loads on heavily loaded gear boxes … to supplying more economical plant compressed air … to reduced drag on extruders, chain drives, pumps, mills and crushers … to improving fuel economy in over-the road and off-road equipment … swepco’s energy savings lubricants have proven they can reduce energy requirements as much as 4-1/2% or more in common, real-world applications.As swepco lubricants reduce the friction that increases energy consumption, they also reduce the wear that shortens equipment life. So you get the added benefit of lower maintenance and repair costs and longer equipment life. And because swepco brand lubricants deliver drain and re-greasing intervals that are typically three to five times longer than conventional lubricants, they save the environment too.
dick
