No, I have not met the manufacturer's recommendation as far as the p/g.
Probably 20,000 / 25,000 miles (or so) instead of the recommended 12,000 miles(?). (based on "color", sometimes)
any more, it is a pita because the recycle places only take motor oil -- I have to put it in a jug and take it to the household hazardous waste drop off.
Yes, I realize about the torque converter, and, no, I would never pull the engine / transaxle to drain it. (I do not have the jack or the will, lol.)
actually, my (late) corvair mechanic (late 70's to early 90's -- started his corvair shop in the early 60's) hardly ever drained a p/g torque converter that I can recall. He had plastic plugs to keep them from draining if he separated the trans / transaxle. Vaguely recall him having torque converters (spare) that he had removed with the plastic plugs in them. I cannot remember the reason why -- too long ago. He could also rebuild p/gs, if necessary.
Yep, understand about things "falling apart" -- but at this point, I am not sure that there is any difference with dexron v / vi in this regard.
Never been much "sludge" / "debris" in the pan when I have removed it -- just a thin "film" -- mostly "friction material" from the clutches, I assume.
Thanks for the reply / concern. I will think about this a little more.
