Swapping to gm column
Gotscout269
Hello I had the dash out rewiring I have the long steering column so I thought I would change out the column while I have the dash out went to the junk yard picked up an 80's floor shift column it's a jeep / gm column just wondering if anybody knows what adapter will work to go into the scout 80 manual steering gear , I am planning on doing power steering down the road but for time sakes just gonna mock it up to old steering gear for now , thought about double D then cutting old shaft any other ideas are appreciated ? Also any good wiring install kits for the column available it has cruise which I won't be using but I plan on wiring in electric wipers and using the hazard switch on column and turn signals .
