suspension swap
62ihscout
I have a 62 Scout 80 4 wheel drive and I am wanting to put a lift on it and up grade the Dana 27s to Dana 44s front and rear. I saw the front end kit that they sell here and was planning on using that but what about the rear what should I use there? Can I use the front end kit?
I'm not sure I really understand what you're asking? Are you asking if you can use the reverse shackle kit on the rear? If so then the answer is no. Also it sounds like you are thinking that the kit will include a Dana 44 front axle. This is not the case. Please clarify your question so we can help you out.
I guess what I am trying to say is can I use the CPT long travel front suspension kit on the back and the front? If no what do you suggest I do? Or is there a rear suspension kit? I could not find one. I do realize that the kit doesn't come with the Dana 44 axles I was just stating how I wanted to set it up. Thanks:)
