my 67 Scout 800 has a leak in the rear axle. Trying to find out what's all involved with taking it apart. Is this a "floating" axle?
Help!
Actually, you should start a new thread because, even though axles are somewhat similiar, your 800 is different from a 3/4 ton pickup / t/a.
No, your axle is not what is called a "full floating" axle...
Where is your axle leaking from? -- the center where the differential is? Or, is it leaking from the axle seals into the brake drums? Picture?
Difficulty is based on your mechanical experience? Taken axles apart before? Performed a brake job?
Also, the difficulty is based on the condition / "problem" -- has an axle bearing seized? "welded" itself to the axle? Is it leaking from the pinion seal in the differential (where the driveshaft enters the differential ("pumpkin")?
At least, you should have the IH service manual for your 800.
If you look thru posts here, you should find some description (maybe even a couple pictures) to help give you an idea of the work involved...
