DF Sales&Marketing
Oil Tech Moderator
Summertime heat can take its toll on cooling systems already taxed with engine operating temperatures at around 225ºf. Today’s engines have a much tighter cooling margin than previous models. As a result, proper coolant and cooling system maintenance becomes increasingly important to maximizing system life and maintaining its efficiency.
Just how important is coolant formulation and system efficiency? A 50/50 mix—50 percent concentrate to 50 percent water—brings the coolant’s boil point to 225ºf at sea level. That’s the low end for an engine today that operates at 225ºf. But every added pound of pressure raises that boil point another 2.7ºf. So a 14 pound pressure cap raises the boil point of a 50/50 formulation to about 263ºf. If a pressure cap or relief valve is defective or glycol levels are inadequate, boil point is right back down to engine operating temperature.
About a 40º buffer provides adequate protection against boiling. When conventional coolants are allowed to boil, glycol decomposition can cause several problems. The chemical reaction results in oxalic acid. This “burnt” coolant has a very distinctive dark brown-gold color and an even more distinctive odor. It creates a “varnish” that covers internal system components, prevents the system from operating properly and is extremely difficult to correct. This varnish must be flushed, the system thoroughly cleaned and any hot spots corrected before new coolant can be introduced. Monitoring system condition and strip testing the coolant at every pm can keep the system running smoothly and without unexpected interruption.
Our favorite cooling system treatment is a product called rmi-25 cooling system treatment. It has been shown to be an effective deterrent used to help control electrolysis and is a complete cooling system treatment which protects against rust, corrosion, cavitation and low ph readings. Test for ph with a test strip and treat, or add 8 ounces per 5 gallons of coolant every 15,000 mi / 300 hrs for best results.
Rmi-25 is the only product on the market which can be used with standard, or long-life coolants and the only product we know of which contains an effective cleaner to keep the entire system operating cool & trouble free.
It is also highly recommended for vehicles which do not use anti-freeze such as in racing and off-road applications as it gives full protection, except for freezing.
Rmi-25 is bio-degradable and non-toxic when used without anti-freeze, so it is also an excellent product to use when environmental conditions come into play.
It’s multi-function formula works as a cleaner, descaler, emulsifier, inhibitor, lubricator, conditioner, stabilizer, water wetter, oxygen scavenger, and a leak detector (black light) dye.
An 8-ounce bottle treats a 5 gallon system - available from IH only
