The Scout in question is a '77 with a 345, Holley distributor with the gold box, and a 2210 carb. The coil and the gold box are fairly new. We rebuilt the carb, using the correct gasket that doesn't cause a vacuum leak, and it was starting and running sweet for over a year.
Then one day it started missing when climbing hills. Soon it became undrivable. Can barely drive down a flat road, misses and backfires on acceleration. Took the carb apart, it's still spotless inside, and everything was in good working order. Accel pump squirts fuel immediately. Took the dizzy apart, cleaned everything, and replaced the broken advance bushing. Now the mechanical advance is smooth as butter. Vacuum advance has no leaks and full range of travel. Cap, rotor, wires and plugs all look great. Starts easy, but drivability has not improved. Playing with timing doesn't help.
Here's my last ideas:
1.coil has failed - but I would expect it to run worse as the engine warms, instead it is equally bad.
2.the pickup in the dizzy has failed - but then why would it idle perfectly?
3.the gold box is failing - could this cause a weak spark that would ignite idle mixture but not a richer acceleration mixture?
I'm not sure what else to check. Any ideas?
