RobG
Ok, the best I can figure now is the lifters are not pumping up. I've replaced the lifters on my 152, checked the head, and everything else related to the valves. The only thing I can come up with is the oil galley for the lifters is not pressurizing properly. I pulled the front cover to see if a galley plug was left out but it doesn't look like there is one in the front. Does the lifter galley feed from the back cam bearing? If it does what is the best way to fix it? I'm guessing the bearing was put in wrong and blocking the oil passage. Do I have to pull the engine or does the oil feed from another place?
Rob gimmel
Rob gimmel
