I need advise! Im having some steering issues I can't figure out. Let me give a little run down.
72 sii, 345, auto, 4" Skyjacker,33" tires, all new bushings including body. 5" shackles. Dana 30 front, cut and turn 5 deg + caster. Toe in 1/8", replaced rag joint with ujoint. Has a rebuild steering gear box from IH only,installed by previous owner. Repacked wheel bearings. Have not replaced tie rod ends or ball joints. Ive tried to make them the problem but they have no play any direction. Ive played around with the lash in the gear box.
Now having said all that I still have some bump steer and wandering going down the road. This is my daily driver and I want it to drive straight. Im thinking of building a straight steer and maybe a rs. Any thought on where to go next. At least 10 times I have jacked up the front end and checked for loose components also checked on the ground with a helper lock to lock and just dont see any wore out parts. I dont want to throw good money after bad trying to track it down. Any held would be appreciated.
