Spin-on oil filter conversion
Hi,
I finally took possession of my loadstar this past weekend. And these are the first of many questions.
What do I need to convert my oil filter from the canister type to a Scout type of spin-on filter that points downward?
Attached in the pdf is a picture of the type of oil filter I presently have. Any advantage to a canister type filter, or is that old filtration technology?
Also, are all oil dip sticks the same for the 266, 304, 345, and 392's?
Thank you.
Steve
  • engines-3.pdf
It looks like you just need the spin-on adapter from a newer sv series engine.
All the dipsticks I've seen are the same. There are 2 holes in the upper bracket with the 266/304 using the upper hole and the 345/392 using the lower hole.
