SOLD***1979 Scout II***SOLD
usual suspect
1979 International Scout II
IH 304 V8 with fuel injection, 153K miles, 727 trans, Dana 20 t-case, Dana 44 axles f/r with 4.09 gears, 4" rough country lift kit, 15x8 black steel wheels with New 33x12.50 Goodyear Duratrac tires including full size spare, 3” Flow Master exhaust, hard top, bikini top, folding rear seat, factory roll bar, front bench seat, clean interior, no cracks or rips in vinyl or dash pad anywhere, sliding side windows on hard top, SSII grill with Line-X, heater works and AC works (but probably needs to be oiled and then recharged again - I never use it), 4x4 works great.
5th owner, owned it since 2009. I have the title in hand. Documentation includes the original invoice, line set ticket and receipts of work performed and parts by me and previous owner dating back to 1993. Summer of 2007 previous owner disassembled and repaired rusty spots then applied primer and flat green/flat black paint. The entire tub and the lower section of the outside have been coated with Hurculiner.
I have had work done at several IH specific restoration shops over the years, and the records and invoices for it. As you’ll hopefully read through below, I’ve dumped all sorts of time and money into trying to improve the truck as best I can. It is a solid truck. It has been a fantastic vehicle for me, with many great memories, but I haven’t been using it much the last few years. So now it’s time to pass along the fun to the next person who wants to enjoy a classic IH with modern upgrades.
New:
Hamilton Throttle Body Fuel Injection - so also new Distributor, coil, fuel lines, spark plug wires, etc
Hydraulic assist brakes (instead of vacuum assist)
Transmission just rebuilt
CPT Reverse Shackle kit for front axle
CPT Heavy duty SUA bolt plate kit front and rear
Bilstein Shocks front and rear
Borgeson Steering kit - couplers and shaft
Steering box, straight steer brace
Slotted brake rotors front, rebuilt drums rear
Rebuilt entire front axle
Cut and turn front axle to align front driveshaft, 5* castor
All new wheel bearings, ball joints, poly body bushings, poly transmission mount, Engine mounts
Front cab metal body mounts
All wheel U-joints and driveline u-joints new Dana Spicer heavy duty
33 gallon fuel tank
4 post solenoid for starter
New door hinges (with grease fittings)
Freeze plugs, water pump, Rear main seal
Brake fluid flush, coolant flush
Rebuilt speedometer, also has appropriate calibration gear box
Other:
Xenon head lamps
Fresh weather stripping throughout
3 point seat belts in front seats
Lap belts for rear seat
Stereo system all marine grade components
Windshield frame and glass
Lift gate frame on hard top, gas shock hinges
Emblems and chromed metal marker lights (factory marker lights were plastic in 1979)
List keeps going and going…
Comes with extra front and rear drive shafts, hardtop interior panels, used fender flares(not installed) and any other extra parts I have...it all goes.
Asking $28,000
Contact me with any questions. If you would like more pictures and videos let me know and I can send you a link to a dropbox file.
Thanks
Mike
