soa
JMiller
Jeff,
do you have an "SOA" kit for a 76 Scout II? I know I will need spring perchs & prob shock tabs for the rear. I guess 1 spring perch for the front? Drop pitman arm? Steering rod arm thingy?
If I just do a spring over in the rear is there a way to match the height in the front with a reverse shackles kit?
Thanks,
jarrett
First off sorry for the late reply. We do not offer a SOA kit but certainly can put a list of parts and prices together and forward it to you that you will need in order to perform a SOA just like the ones we do here in shop. Best to call and either myself or one of my guys will be glad to assist you.
Ok...thanks. I'm still not sure which direction I want to go right now. I'm cruising doorless/topless on some dirt roads and ranches and the dust is horrible. Rolls in where the doors go and boils up over the tailgate and into the Scout. Was thinking best way to deal with it was to lift even higher than it is now and hope to get body openings out of the draft...???
I doubt lifting the Scout higher will have much affect in reducing the amount of dust that rolls in.
