4" SUA lift can fit 33's, 4" SUA lift and 3" body lift can fit 35's. SOA can rub with 32's if you want, 33's fit pretty good. 35's can fit with some minor (or major depending on your desire) trimming and limiting the up-travel (lower bump stops) as needed. Any body lift or spring lift on top of that help with less trimming.
Mount them up, then flex it out, then trim or bump stop to get your desired results.
