SOA/RS sway bar
Eric Knutsen
Hi team.
I fitted your rs kit with my SOA d44.
Easy to do once I committed my self with the first cut.
I like the kit and install and the ride is improved but now that I don't have the flat bar sway bar I have noticed some body roll when cornering.
Do you have sway bar kit. Or can you recommend a doner car I can use to fit.
Eric
Eric,
we don't have the front sway bar listed online as it is more of a custom setup at this point. Here is one of our builds with pictures of the install part way down: http://forums.IHPartsAmerica.com/showthread.php?t=496
It involves a new tierod and draglink, pitman arm, Ubolt plates, bumpstops, and the sway bar components. Everything is a real tight fit, but ends up working well. Current pricing is $915.
For a donor, I would go to your local junk yard with your Scout and walk around. A tape measure will be handy as a narrow truck like a toyota, s10, ranger, etc might have an appropriately sized sway bar. We have used some stock bars in the past, but they were always different depending upon the project. Thanks.
