smaller tstat housing for 304?
coolpete1
is there a smaller tstat housing to fit a factory 304 intake? this thing takes up way too much real estate.
Buy and offset air cleaner base in your desired size or just run a 10" air cleaner which is plenty of flow for these old engines.
1975IH200
Easy enough to reroute the heater hoses to wherever you want them. You may need to buy some longer hose to accomplish that.
Most commonly, heater hoses are routed down the driver side of the engine, then cross over behind the filter housing to the heater core. As previously mentioned, that requires a longer run to accomplish.
