Hi all, I have been thinking about adding a fan shroud to my rig and had a question. I have read the diesel shrouds are steel instead of plastic. Is there a reason? Runs hotter? Can I go with plastic? Thanks
They don't run hotter.
Either material will be fine if you intend to build one. Easy with sheet metal and you should think about rimming the fan opening.
