several 70's pickups...
darren y
Several 70's trucks
I'm looking @ selling early 70's pickups....
71 1210 - farm truck rusty- SOLD
72 1200 - old fire dept truck- SOLD
73 1300 - one ton no bed or motor- SOLD
74 1500 frame/axles
71 1110 4x4 complete 345 4spd
71 1600 Loadstar frame with 345/Allison
any interest in parts?,
best offer
possible trades for ??
Located Sparks, NV 89436
darren y
1200 = 2wd 3/4 ton
1210 = 4x4 3/4 ton
1300 = 2wd 1 ton
1500 = 2wd 2 ton
73 shortbed is a 1110 = 4x4 1/2 ton
windshield yes a couple nice ones
How about a working pre-'72 wiper motor? They changed significantly in m/y '72. If you have one, I'd need a picture just to confirm it is the style I need. Thank you.
Greg R
My 71 1210 needs a good dash pad with radio grille and the lower steering column trim piece. They're both black.
Are photos available?
Thank you.
61_C-120
I was interested in what the wheel and axel package was on the 1200 2 wd. 6 lug? Drum? Dana 60? Gears in the rear (4.10 or 3.73? Also any idea of mileage on that stuff and photos would be great.
Tks.
Brett
darren y
I need a front right fender. You wouldnt happen to have any orange ones?
Fender yes, orange no
make offer
how about a working pre-'72 wiper motor? They changed significantly in m/y '72. If you have one, I'd need a picture just to confirm it is the style I need. Thank you.
Wiper yes, pic no
(send me a pic of the one you need)
my 71 1210 needs a good dash pad with radio grille and the lower steering column trim piece. They're both black.
Dash pad maybe (I'll have to search for it)
steering column trim - no
pics no (maybe later)
Tks.
Brett
1200 2wd, should be a 60 rear, 8 lug drum, 3.73
mileage ?? (it almost 40 years old!?)
looking for 71 1210 t-case. If your parting your truck out I wouldn't mind picking up some of the running gear. Email me at ihscout4x4@hotmail.com Or by phone at 408-348-8727 thanks alot
alex
Got a gut looking to buy the 1210 complete (for the running gear), the body is beat, engine is bad but drive train in good
won't be able to move it out til sept.
But $$ talks, where are you located?
Wiper yes, pic no
Sadly that won't be possible. I thought I had one, but I was mistaken. The original unit is now gone. I can describe it though. On the outside of the motor housing where the wires make their penetration, you will see what looks like a small, yellowish resistor soldered in place. This is not so on the later motors. Also, instead of a threaded, rectangular shaft penetrating the firewall in a perpendicular fashion, there is a rectangular adapter that is roughly two inches long by 1/2 inch wide by 1/8 inch thick that rests in a cradle parallel with the firewall when the motor is secured to the bracket. This allows the motor to be completely removed from the firewall without having to disconnect anything inside the cab besides the wiring pigtail. Later models require the motor to be separated from the wiper arm mechanism by removing a nut and/or c-clip from the shaft up under the dash. I hope this is a clear enough physical description for you to make a differentiation between the two styles. Thank you.
ihscout4x4
But $$ talks, where are you located?[/quote]
Im in the east bay in livermore CA, not too far if you in reno. Is the transmission a automatic or a manual?
I had gotten a 1210 complete myself and put all the running gear in my 70 Scout 800a.
How much were you thinking for the t-case?
gulfdawg
I am definetly interested in a straight fender even if it isnt orange. Do you have any with trim? I can drive up and pull it, how does $50 sound? I May also find some other stuff I need. Hopefully. Thanks justin
darren y
$50 for a fender is good, let me check to see if any have trim, your more than welcome to look thru my trucks....
4 speed with divorced transfer case, make offer
darren y
hey do u still have the trucks? And do u happen to have a tailgate for a long box.
Yes/ no
have one thats beat up '71
another that is on a truck that is complete '72 or '73?
I'd like to sell complete truck as a whole
darren y
sold last tailgate a couple months ago to a local guy, (the one who bought my gold 73 travelette a couple years ago), so no tailgates left
Raider2.6
do you have any rear bumpers and frame brackets need one for a 72 1210
also looking for a complete T34 transmission
