76bluescout
Ok, I wasnt really paying attention when I was changing the oilpan seal and when I was dropping the pan I missed the bar that holds the tube to the manifold. One good tap on the pan later to break the seal loose and the pan came down, but of course the tube stayed in place and came out of the pan.
Now im trying to figure out what actually sealed the tube to the pan, there is some goo in there that looks like it was a gasket sealer to help seal it up, but with the diy garbage that ive seen on this truck so far I dont trust anything anymore. (it really opens your eyes when your sliding under the truck and see a drywall screw where there should be a body bolt.. Seems the front cab mount rusted away and the po decided to put a hockey puck there for a spacer and run a drywall screw there to hold it in place
so for the life of me I cant find anything that tells me how the tube was attached or sealed to the pan, please tell me its just a press in friction fit that magically seals itself! (yea right my luck its prob brazed in from the factory and the po put chewing gum in there to hold it inplace when it broke off)
