Carl Childers
I have a Silver Diamond 240 engine in a 56 S120 truck that uses oil and smokes. A leak down test shows all cylinders are good and the motor sounds and runs strong. I have had other brand motors in the past that did this and replacing the umbrella seals on the valve stems fixed the problem. Looking at my shop manual it shows the valve train but no stem seals. I also have noticed stem seals listed for this motor on the aftermarket.
Did IHC use stem seals on this motor from the factory?
Is there maybe something else I am overlooking that may be causing the problem?
Any help or opinions on this would be appreciated.
