scout ll parts
I have all three gauges and new circuit boards with the gauge cluster cover. Passenger side vent window with frame and perfect rubber seal. Stock rear step bumper with the mounting brackets. Complete drum brake set up for Dana 30 with after market steel braided brake lines & proportioning valve wheel bearings knuckles brake pads the whole 9 yards just bolt it up and go. All has about 1000 miles on it. Stock spread bore intake manifold with new plugs installed, boiled & painted aluminum color. Some longer after market u-bolts never been used. Tranny kick down linkage for automatic. Dana shifter stick & boot with all the other stuff too. Stock fuse panel work fine when I replaced it with after market kwik wire setup. Over flow tank. Stock motor mounts. My # is 707-459-1892 ask for Mike. Make me an offer if u see something u need or want. Located in northern California.im
is the intake in good condition and was it for a 345? Does the overflow hold coolant? No leaks?
The intake is perfect I had it on my 345 that has 800 miles on it. I had the intake boiled, new intake freeze plugs installed & I painted it aluminum engine paint. The over flow does not leak. I switched it out for another I pick up that looked brand new. Other then that no leaks and the intake is ready to go. Where u located.
I tried to mail u pics not sure if u got them. Your e-mail address was wrong or wasnt working for me.
Got'em Mike and just replied via email. Good lookin' intake but I think you can sell it/ deserve more than I can spend on it right now. Havin' 3 concurrent projects is forcing me to seriously watch where every penny goes at this point and I've got some things over here that are taking priority...
I'll post up the pics you sent me for others interested Mike.
Thanks,
john
Mike this is admorri on the 727tran. Looks like we need to deal. Did you say you would take $250. Also what is shipping to rogers arkansas 72758 zip. E-mail me right back so we can make it happen or call me at 479 640 4926, waiting and ready. My name is dell.
